Der Umbau von Rick (Webbi von Explorer.com) beinhaltet u.a. folgende Einzelheiten:
Stats for Rick's 1993 Explorer XL
Engine 4.0 Liter V6 EFI, Pro Dyno custom exhaust, Hi Flow Catalytic Converter, KKM True Rev Intake Kit,
Transmission 5 - Speed Manual
Transfer Case Advance Adapters Atlas II 4.3:1 Ultra Low Range
Front Suspension Custom FST 4 link solid axle conversion with Bilstein Coil Over Shocks.
Rear Suspension National Springs 5" lift springs, relocated over axle, Doetsch Tech 3000 Shocks, FST shock mounts, custom shackles.
Ramp Travel Index 970 A stock Explorer scores about 440.
Differentials ARB Airlockers Front and Rear 4:88 Gears
Axles Front - Dana 44 Solid Axle, Moser axle shafts, CTM U-Joints, '80 Chevy Blazer rotors from Applied Rotor Technology, hubs, spindles, calipers 5 on 5 1/2" bolt pattern, Superwinch manual hubs.
Rear - Ford 8.8" w/ '85 Mustang SVO disc brakes. Moser axle shafts 5 on 5 1/2" bolt pattern.
Fiberglass Bodywork 1998 fiberglass front end. Pre-runner style fenders. Fiberglass by: Perry's Fab & Fiber
Communications Icom 2800H VHF/UHF Transceiver, Icom 706 HF Transceiver, Garmin GPS III+
Winch Ramsey Pro 9000
Electrical Dual Optima Batteries,
Tires/Wheels Swamper SC 35x14.50-15 On 15x10 TrailReady beadlock rims
Air Supply Dual ARB Compressors, CO2 tank.
Skid Plates Custom Front Differentia lCover from FST, Transfer Case, Transmission, Fuel Tank
Bumpers Front Custom FST, Rear Tire Carrier - Gas Can Carrier - Bumper by FST
Nerf Bars Custom FST Nerf Bars, 1/4" wall rectangular tubing.
Roll Cage Full Roll Cage by FST
Ist also hauptsächlich an der VA komplett geändert worden.
Die HA is ja noch die Originale 8.8 nur mit anderen Federn auf die Achse montiert.
Daher auch:
Ramp Travel Index 970 A stock Explorer scores about 440 !!
Hier das Teil mal auf der Rampe
