Kits für 300 Tdi werden z.B. in GB angeboten und ich bin interessiert.
Habe bei einem Umrüster in D angerufen, der meinte, das wär in D nicht zulässig. Weiss jemand warum nicht?
Grüsse, Norbert
Dieselgas
@ marco
kannst u.a. wg. dieselgas mal in dem thread hier mitlesen. Scheint mir aber auch wg. der intercooler-ausführungen interessant:
http://www.aulro.com/modules.php?name=F ... 844ddf7fc6
Grüsse, Norbert
Grüsse, Norbert
sieht nach einer spannenden Sache aus, auch wenn ich keinen Defender mehr hab, technisch interessant!
Ein Bekannter von mir hat Dieselgas im 38a. Bilder sind auf http://www.iwemalpg.com/Diesel_LPG.htm . Er ist aber etwas später nicht mehr so ganz glücklich damit:
Carsten
Siehe auch hier.Whose bleeding Range Rover do you think it is in the pictures?
BTDT. My current views are based on experience.
Thanks for the thought though.
- - David, Derbyshire, UK. '95 P38 - 2.5DT
-----Original Message-----
Sent: 23 June 2005 09:57
David,
Perhaps you would be interested in this article on LPG in modern
diesels?
http://www.iwemalpg.com/Diesel_LPG.htm it might not be "off the shelf"
for DIY purposes, but it is possible.
Jim
RRC 1983 4 door "Goldminger",
3.5 V8, 3 sp Torqueflite Auto,
265/65/16 Amazons,
Hoping to convert to SU's.
Sent: 22 June 2005 22:08
SNIP
I have tried the other gas conversion, mixing some LPG vapour into the
inlet air stream, feeding the diesel.
I haven't found the fuel combination to be cost effective, in terms of
fuel cost per mile.
I'm convinced the result varies with which engine is so modified, the
worse the stock engine, the better the comparison.
Accurate control of the LPG quantity is also important, the more so the
more advanced the diesel engine.
There is no 'off the shelf' system to provide this accuracy.
"his diesel 5 series which had me drooling for the economy/luxury
combination. "
The current BMW diesel engines are amongst the best in the world for
luxury performance / economy, in the cars they are designed for. Adding
an extra tonne to the vehicle carcase blunts the benefits.
Carsten
