Seite 155 von 211
Verfasst: Mo 13 Feb, 2017 00:19
von mo
Vom GAZ-44 kommt glatt auch noch eine kurze Sequenz rein
https://www.youtube.com/watch?v=cNN04CmhDGQ#t=25m29s" onclick="window.open(this.href);return false;
Verfasst: Mo 13 Feb, 2017 15:08
von mo
Ich weiß nun nicht, wie lange ich schon nicht mehr weiß, wie Formel 1 -Autos gerade aussehen oder wieviel Hubraum sie haben, doch wie sie inzwischen wohl
zünden, hab ich mitbekommen. Über dieser Animation ab t=10m12s: youtube.com/watch?v=44COhFH8WX4#t=10m12s
Eine Erprobungsvariante GAZ-51F bekam Vorkammerzündung. Anreicherung dazu über kleinen Kanal ab Vergaser und drittes Ventil.
https://commons.wikimedia.org/wiki/File ... %D1%8C.jpg" onclick="window.open(this.href);return false;
Then, based on engine GAZ-51 was created by a variant of this power plant - GAZ-51F. He had a head with three valves per cylinder, driven rods, and dual carburetor. The basis of a new method of improving the economic and other indicators of a gasoline engine was the idea of a sharp increase in the power of an ignition source, which almost became a torch flame. The main objectives of which are prosecuted in this case is more complete combustion of residual gas in the combustion chamber and the need for better utilization of heat burned gases. Immediate vicinity of the combustion chamber engine of the GAZ-51F provided for a small preliminary auxiliary combustion chamber - prechamber, which communicate with the main short channels of small cross section, having a sharp outline. In the settling chamber was applied a small amount of very rich mixture, ignited a spark from a candle. During the combustion of the mixture pressure in the plenum chamber increases. And as the section of exhaust ducts were small, it was several times higher than in the main combustion chamber. Reactive products of incomplete combustion of the auxiliary mixture dumped in the middle of the combustion chamber, swirl it working mixture and formed into her special turbulent structure, causing flooding activation of combustion. The degree of compression engine GAZ-51F on petrol of mark A-66 was able to raise from 6,2 to 6,8, the power at the same time increased from 70 to 85 hp at 3000 rpm, providing a significant increase in the dynamic properties of the truck while reducing fuel consumption. An experimental batch of motors 78 hp mounted on buses and grain wagons, which in 1961 passed the performance tests in Moscow and Sochi. They were 15% more economical than cars with conventional engines, but had a number of trudnoustranimyh deficiencies in those years.
http://russki-ya.blogspot.de/2011/04/in ... ne-in.html" onclick="window.open(this.href);return false;
Das ewige Gesetz der Mangelverwaltung nach Règlement – bis eines Donaldstags die unsichtbare Hand...
Verfasst: Di 14 Feb, 2017 13:35
von mo
ZiL OHC mit ohne Deckel
https://vk.com/wall-110500597_23" onclick="window.open(this.href);return false;
und mit ohne Vergaserspinne
https://vk.com/wall-110500597_461" onclick="window.open(this.href);return false;
https://vk.com/wall-110500597_391" onclick="window.open(this.href);return false;
https://vk.com/wall-110500597_478" onclick="window.open(this.href);return false;
https://vk.com/wall-110500597_215" onclick="window.open(this.href);return false;
http://anthrax-urbex.livejournal.com/5281.html" onclick="window.open(this.href);return false;
Verfasst: Sa 25 Feb, 2017 01:36
von mo
Ein Cosmo
http://forums.vwvortex.com/showthread.p ... st82706619" onclick="window.open(this.href);return false;
wär jetzt recht, wenn ich schon mein Kistl aufgeben muß, aber Mazda hatte neben Miller-cycle und Scheibenmotoren offenbar noch eins in die Ära gebastelt:
W12 für Amati 1000
http://www.invetr.com/powertrain/category/all/13" onclick="window.open(this.href);return false;
Verfasst: Sa 25 Feb, 2017 06:15
von WJM
Feine Sache, dessen Riemen zu wechseln. Besonders ohne Versatz der Nockenwellen-Stirnraeder.
Aber Buchstabe W hat immer etwas feines, versteht sich.
(obwohl ich meine das haetten hier schon je 6-Zylinder sein sollen, damit das alles von vorne rein schoen sauber rund laeuft)
Verfasst: Sa 25 Feb, 2017 20:23
von mo
Hast Du irgend einen Motor mal mit so verborgener Nockenwelle gesehen? Hätte auch der Mercedes 6.9 nicht, oder?
Verfasst: Sa 25 Feb, 2017 21:21
von WJM
mo hat geschrieben:Hast Du irgend einen Motor mal mit so verborgener Nockenwelle gesehen? Hätte auch der Mercedes 6.9 nicht, oder?
Vom 6.9 weiss ich nur dass der Trockensumpfschmierung hatte.
(deswegen ein feiner Gelaendewagenmotor; nur schade dass die Handschaltgetriebe arg rar sind)
LKW-Herkuenft scheint ein Mythos, nix handfestes.
PS: Bucher/MOWAG Duro II 6x6 scheint momentan den Markt auch zu ueberfluten; sogar de-mob Exemplare mit nur 100km.
(da scheinen wieder viele Millionen vergeudet (UK, aber trotzdem meist linkslenker, Gottseidank))
Nur wegen dessen 5,9L Cummins schon etwas nettes....
(Bodenfreiheit ist aber ziemlich mau, fuer einen Portal-Axler)
(das DeWatt-Gestange dann wieder fein)
Verfasst: So 12 Mär, 2017 22:42
von mo
Ein paar Bilder mehr vom Wackeltraktor:
http://strangernn.livejournal.com/1392214.html#cutid1" onclick="window.open(this.href);return false;
Interessanter Cummins
http://strangernn.livejournal.com/1350671.html#cutid1" onclick="window.open(this.href);return false;
Verfasst: Mo 13 Mär, 2017 09:54
von mo
https://youtu.be/3KPYIaks1UY?t=76" onclick="window.open(this.href);return false; Bose-fun
Verfasst: Mi 29 Mär, 2017 20:31
von mo
Es bröseln eben auch die Benziner von heute gerne – ob JLR den Filter wirklich noch nicht besser ausgesucht hat?
https://images.cdn.autocar.co.uk/sites/ ... k=mRWSmDBd" onclick="window.open(this.href);return false;
http://www.autocar.co.uk/car-news/new-c ... 017-reveal" onclick="window.open(this.href);return false;
